multiple rs232 devices on a single rs 232 port on cRio
Hello
I am communicating to a serial device connected to a cRio NI9076 succesfully using NI VISA. It has only one rs232 connector.
Now I need to connect two additional serial periphical devices to the cRio NI9076, which has only one rs232 port. Can I use an rs232 hub and still communicate using NI VISA? Will MAX recognize this?
Thank you!
(5,712 Views)
one RS232 port per instrument
(5,698 Views)
Hello Manuel,
the problem with HUB is that most of them need a driver to be installed and it's very difficult to found one compatible with OS Real Time. In any case there are a couple of solutions for your question.
You can either use a "passive" hub that does not need a driver like: ENET-232 or ENET-485
Can I Use the ENET-232 or ENET-485 on Systems with VISA Support Only?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LveSAE&l=en-US
or you a module 9870, 4-Port, RS232 Serial Interface Module for CompactRIO
https://www.ni.com/en-us/shop/model/ni-9870.html
I hope this help,
regards,
Valerio
(5,672 Views)
Thank you for the hints.
I think the module could be a solution. Another thing I suppose I could do is to simply use an RS232 to USB converter, like this one:
http://www.startech.com/Cards-Adapters/Serial-Cards-Adapters/4-Port-USB-to-RS232-Adapter~ICUSB2324
and directly connect it to the Host PC.
(5,666 Views)
