nat7210
Hi
I have a bord that use to convert serial communicatin to GPIB comunication with NAT7210 chip, the Reset PIN of the NAT7210 connecterd to the GND is this right??
thank's.
(3,106 Views)
Hi agbaahmd!
If you never want the chip to be reset, from a quick look through the specs, it seems it should be grounded as you suggested.
From page 4 of the datasheet linked below: "Asserting the reset input places the NAT7210 in an initial, idle state"
https://www.ni.com/docs/en-US/bundle/nat7210-4882chip-specs/resource/372012d.pdf
Hope this helps.
Michael G
Michael G.
Self-realization: I was thinking of the immortal words of Socrates, who said, "... I drank what?"
(3,096 Views)
