nat9914 Controller, how can I change to talker/lisner
hi
I hope you understand I speak english little bit.
i have probrom.
I have developed NAT9914 Controller.
I will initialize Controller mode and change talker/listener.
initialize code...
outp(R7210_AUXMR, C7210_SW9914); // Make sure GPIB chip is in 9914 mode.
outp(R_AUXCR, C_CH_RST); // Reset the NAT9914. Logically remove device from the GPIB.
outp(R_ACCR, F_ICR | F_16MHZ); // set clock speed
outp(R_AUXCR, C_CLRPI)
outp(R_AUXCR, C_VSTDL);
outp(R_IMR0, B_BO_IE | B_BI_IE); // Byte In Interrupt Enable bit and Byte In Interrupt Enable bit
outp(R_IMR1, B_DCAS_IE | B_GET_IE); // Device Clear Active State Interrupt Enable bit and Group Execute Trigger Interrupt Enable bit
outp(R_AUXCR, C_PIIMR2);
outp( R_IMR2, B_CIC );
outp(R_AUXCR, C_PIACCR); // Page-In Accessory Register
outp(R_ACCR, F_ACCRB | B_LWC | B_ATCT );
outp(R_AUXCR, C_CLRPI)outp(R_ADR, gpib_addr); // set the GPIB address of the device
outp(R_AUXCR, C_NSWRST); // Clear Software Reset
outp(R_AUXCR, C_SIC);
outp(R_CDOR, UNL);
outp(R_CDOR, MAT1);
but  don't change talker register TA/listener register LA.
What is wrong?
Do I  implement a handshake function?
if write command/data to CDOR,
data sent automatically by the handshaking?
i refer to the NAT9914 Reference Manual Chapter 6.
please help..
Message 1 of 1
(4,408 Views)
