09-10-2005 05:57 AM
09-10-2005 11:20 PM - edited 09-10-2005 11:20 PM
Message Edited by ni_n_hp_fan on 09-10-2005 11:21 PM
09-11-2005 12:26 AM
Thanks for your kindly advice.
My Stage System is purchased recently. and PCI - GPIB Board is purchased in 2002.
My PCI-GPIB card is Communicated other instrumenet such as HP Function Generator.
I check communication between HP Function Generator and GPIB Board with Same GPIB Cable
Manual of Newport PM 500 have two Comunication methord that are RS232 & GPIB.
and I take your advice, Manual Listed commands query communicator form Max.
Some commands are available and some are not.
So Some command - example H (move to initial point)- Move my stage system to initial point but communicator window has tiemeout error.
*idn? and other command of manual are available before install plug and play.
and I can`t understand SCPI command at all. so I hope you give me a explanation of SCPI.
thanks
09-12-2005 03:26 PM
