ni-488.2_20.0_online_repack3.exe is missing digitally signed drivers
The following drivers are not digitally signed:
NI mx Driver Framework, service nimxdfk
NI Measurement Routing Utilities, service nimru2k
Forwarding PXI Chassis Pilot for 3rd-Party Trigger Managers
NI PXI Resource Manager
Generic PXI Chassis Pilot
NI Device Interconnect Manager
National Instruments PCI Bridge Driver
NI-PAL 1394 Legacy Wrapper Driver
NI-PAL USB Legacy Wrapper Driver for WIndows
NI Measurements DeBuG Library
NI Object Request Broker
and maybe more...
Is this a problem?  The installer says the programs that use these drivers will not work and I should contact the vendor, but NI says I am not qualified to receive support.
I have two registered modules, both NI GPIB-USB-HS+ modules that I need to use with a Windows 7, 64 bit computer, but the software wont install.
I have also tried earlier versions, 17 and 18, but both of them have drivers that are reported to be defective and they dont install properly either.
After completing installation of 20, and rebooting, my computer runs startup repair because something has been corrupted by the installation.  THis is repeatable for at least three re-installations.  After "attempting repairs" the computer fails automatic restart, but can be manually restarted.
After rebooting, I run NI MAX and get "Unexpected Internal Warning - Measurement & Automation Explorer"
Where do I find an installer that works?
Message 1 of 1
(1,704 Views)
