ni usb 9213 could not be found by signalexpress
I have a NI USB-9213 for thermocouple temperature input. But the signal express just could not find it, (no devices available). But the NI MAX could find the device. The only error is when I open the VISA test panel and view the attributes, the interrupt in pipe status has invaid property value  (Hex 0x3FFF0082).
Does anyone know how to solve this problem?  I am just a beginner.
Thanks.
(4,535 Views)
I've never used SignalExpress but I know that VISA has nothing to do with the 9213. It uses the DAQmx driver. You might want to post to the SignalExpress board for help in creating a DAQ task. Verify that you've installed the driver first and that the version is appropriate for your version of SignalExpress.
(4,527 Views)
Thanks. I have DAQmx 9.9 already, but I don't know how it works.
(4,522 Views)
