ni visa
Hi
I need to use a daq card 1200, with windows xp. So I have installed measurement and automation 2.2, and ni daq 6.9.3.
In measurement and automation interface, I dont see my port COM3 and LPT1, do I need to install NI VISA or something else and if yes which version is necessary. I would like to know if I need to insrtall something else to see my daq card 1200 on the Measurement and automation interface?
 Thank you very much
       Fred
(4,266 Views)
Hi
Your DAQ card is not via VISA but via the old NIDAQ driver.
Look in MAX devices/interfaces
greetings from the Netherlands
(4,259 Views)
 Otherwise to see my port COM and LPT1 in MAX do I have to install something cause I dont see them.?
     Fred
(4,255 Views)
Hi
Make sure that you have an uptodate device driver installation.
In you case however keep NIDAQ the old version.
VISA complete should give you the com and lpt ports in MAX
(4,236 Views)
Hi.
I advice you to download these drivers :
and
Best Regards.
Romain D.
National Instruments France
(4,211 Views)
