ni4882 driver error in linux
Hello.
I have a linux box with 8GB ram, and a 2.6.9-67-ELhugemen kernel.
In the kernel boot parameters in /etc/grub.conf, there is the parameter setting of mem=4096M.
With this setting, linux boots and the NI drivers load okay.
If I change the parameter setting to mem=8192M (in order to see all 8GB of ram), the NI drivers
decide that the kernel has changed and they error out.
Has anybody else experienced this?
Thanks!
(4,866 Views)
On 32-bit systems NI drivers only support 4GB of addressable memory, so you will need to use the mem=4096M parameter.  If you need all 8 GB of RAM and you currently only use NI-488.2 and NI-VISA then I recommend installing 64-bit Linux and using the 64-bit drivers:
http://joule.ni.com/nidu/cds/view/p/id/1000/lang/en
http://joule.ni.com/nidu/cds/view/p/id/1074/lang/en
Shawn Bohrer
Use NI products on Linux? Come join the NI Linux Users Community
(4,857 Views)
Thanks Shawn.
There's a plan to go to 64 bit, but it's a long road to get there with all the other software.
Meanwhile, we've exhausted the 4GB of ram, and hoped that moving to 8GB would "bridge" us to 64 bit.
Is there a way to reserve memory space for the NI drivers in the lower 4GB of memory, and allow the
rest of the software to use the upper 4GB?
(4,848 Views)
There isn't a way for you as a customer to do this.  Really the drivers need to be modified to ensure that all memory buffers used by the hardware are in the lower 4GB.  One of the problems is that some of those buffers are allocated by the user-mode process and passed to the driver.
You didn't mention what distribution you are using, but as long as it is multilib compatible you can run all of your 32-bit user-mode software without a problem.  In fact our current 64-bit releases of NI-488.2 and NI-VISA contain 64-bit kernel drivers but only provide 32-bit user-mode libraries.
Shawn Bohrer
(4,844 Views)
Thanks, Shawn
We're using CentOS 4.6 here.
(4,842 Views)
CentOS has multilib support so you should be able to run all of your 32-bit apps without a problem.  Of course if you are upgrading to 64-bit I'd recommend switching to CentOS 5.x as well.
Shawn Bohrer
(4,838 Views)
