niRFSA ivi-.net driver isn't listed in MAX Instrument driver software modules after installation
i'm working into ivi details and want to use ivi-.net and ivi-com driver via the ivi configuration store implemented in the MAX.
My Application should use the COM-Factory to get a driver instance (eather COM or .net driver) via the virtual name.
I installed the agilent AgSAn ivi driver (ivi-COM driver for Spectrum analyzers) for this purpose and it is listed in the IVI driver Instruments driver sofware modules list of the MAX. Good.
I also installed the niRFSA driver, according to ni.com there is a ivi-.net driver included. The driver is installed to C:\Program Files (x86)\IVI Foundation\IVI\Microsoft.NET\Framework32\v4.0.30319\NationalInstruments.ModularInstruments.NIRfsa 1.2, but it isn't listed as ivi-.net driver in the max only as ivi-c driver. Why?
Additional i downloaded from the ivi foundation site the R&S iviSpecAn .net ivi driver and installed it. The same not listed in MAX, why?
In advance many thanks for your help
regards
Georg
(5,543 Views)
Hi Georg,
this behaviour seems to be strange. Could you please attach a screenshot of what you see in MAX? Thank you.
Regards Anoj
Anoj Mubarak
(5,498 Views)
Hi Anoj,
sorry for the late answer.
Here the screenshot niRFSA driver is IVI-C and R&S driver is missing:
(5,250 Views)
Hi Anoj,
Here is the screenshot:niRFSA.gif
(5,248 Views)
I'm not sure what you are asking. Right below the IVI-C driver you have selected is an entry for .NET.
(5,237 Views)
Hi evrybody,
I wish if there is someone could help me to find solution to get the niRFSG Intialize options.VI  working in my code. I tried to use it but it seems dosn't work.
Thank you
best Regards
(4,075 Views)
You've hijacked an old and unrelated thread. Please start a new one and provide additional details on what exactly doesn't work. Include any error codes/messages, the resource name, the IVI configuration in MAX, etc.
(4,066 Views)
