niVVGLui.mxx error when running resman
When I run resman on my system I get the message "The niVVGLui.mxx plug-in caused an exception in the CmxAggregateItemUI::GetIcon function in the MAX process." All of my hardware is recognized though and I can continue after I close out this message. I have searched the NI sight and I can't even find niVVGLui.mxx when I do a search. Anyone have any idea what might be causing this?
(1,436 Views)
You better reset NI-MAX database. If it doesn't help, you may try uninstall and reinstall it again.
(1,373 Views)
