Actually that is not true, if you take a look at the makefile you will notice that a good part of the driver is compiled on the target machine. You did not indicate the version of your compiler in your last post. Make sure that your compiler is the correct version and also make sure that you do not somehow have the older driver still laying around. On my redhat 8 test machine I had no trouble installing 0.8.3. I received no warning messages about compiler versions or anything of that nature.
If you have some methods by which I might be able to reproduce this problem, please let me know.
Aaron K.
Application Engineer
