nigpib-linux-0.8.1 for kernel-2.4.2?
I cannot compile the nigpib-linux-0.8.1 driver under Linux kernel-2.4.2. I have the kernel source and headers installed and have successfully recompiled and run the 2.4.2 kernel. (This is under RedHat 7.2).
When I type 'make' I get lots of compiler syntax errors which seem to be related to module version information.
Is there a known fix for this problem, or is something broken on my computer?
(0.8.1 does compile under RedHat 6.1 kernel-2.2.16)
Scott Coburn
(3,336 Views)
This is an interesting problem. What type of errors are being displayed? Could you capture the results of make to a file and attach it?
Randy Solomonson
Application Engineer
(3,336 Views)
Attached is the output from make.
I have since successfully installed, recompiled, and run kernel-2.4.9-6 from RedHat. The nigpib-0.8.1 code compiled successfully with 2.4.9 installed. I then went and removed 2.4.9 and reinstalled 2.4.2. 2.4.2 reinstalled, recompiled, and ran successfully, and the nigpib-0.8.1 was broken again.
Scott
(3,336 Views)
These error are usually a problem with gcc on Linux see the following links for others with the same issue when compiling.
http://www.linuxquestions.org/questions/history/6031
http://groups.google.com/groups?q=nondigits+in+number+and+not+hexadecimal&hl=en&lr=&safe=off&btnG=Google+Search&site=groups
It looks like the header files for RedHat have some errors. Hopefully the links above can you help start the search for the exact problem.
Randy Solomonson
(3,336 Views)
