nivvglu.dll
In an exitinstance method of a vc++ dll I am cleaning up things. When I call viOut16 I get an Accesss Violation error in nivvglu.dll. To be sure the session was still valid right before the line of code I added logic to get the la of the instrument and that worked fine. Anyone with any ideas. Thanks
(3,545 Views)
Have you taken a look at any of the examples? You can find them in C:\Users\Public\Documents\National Instruments on windows 7 or C:\Documentes and Settings\All Users\Documents\National Instruments on windows XP .
Richard S -- National Instruments -- (former) Applications Engineer -- Data Acquisition with TestStand
(3,509 Views)
Yes I did. I looking for the proper place the viclose should it go in the exit instnce method of the dll, this where it is and I do not see it happening in NI spy, bu the line of code gets executed.
(3,462 Views)
Are you getting any error return values from the function? If it executes with no error it should show up in NI-Spy.
(3,449 Views)
