no visa resource on laptop
im using an xbee transciever and have trouble finding the Com port in labview, i know it is installed because i have seen it in device manager and X-CTU software that i have which reads the xbee fine.  but when i use "basic serial read and write program this com port is not available under the resource name.
(3,595 Views)
Having the com port in windows device manager is not that relevant. In order to use LabVIEW, you have to install NI-VISA and the port has to be seen in Measurement and Automation Explorer (MAX).
(3,590 Views)
ok thank you, shouldnt the NI-VISA been installed when i installed labview initially?  or do i have to install it from somewhere else now?
(3,586 Views)
NI-VISA is a hardware driver and it only gets installed if you use the drivers DVD and select it to be installed. If you have MAX on the pc, you can expand the 'Software' listing and see if it's there. If you don't have MAX, then I doubt that you have VISA.
(3,578 Views)
