older 5052A drivers
I am trying to reconstruct a test sequence from a document. It shows the older drivers with the White Icons.
New drivers are not a one for 1 match. In fact they neglected the 5052A / 5052B switch in the Init-ID check.
The old ones could save me a lot of time digging thru the manuals or worse (help file).
(3,780 Views)
Hi Pappion,
I'm not sure what you are referring to.  Which drivers are you specifically talking about?
Nick
(3,759 Views)
