oscilloscope (tds420a missing vi)
Hello All,
I am using tektronix tds420A oscilloscope.And i have  also download drivers for this oscilloscope but when i try to open in instrument drivers it showing some missing vi.I have attached screen shot of this.please help me to find out solution for this problem.
Message 1 of 8
(4,164 Views)
Accepted by topic author royal1
Please don't attach proprietary file formats. It seems there is a problem with the mnu file pointing to to the functions in tktdsxxx.llb. One way to fix it is to go to Tools>Advanced>Edit Palette Set. You can browse to the palettes with the missing items and do an Insert>VIs to select the VIs in the llb and then delete the icons with the question mark.
Message 2 of 8
(4,155 Views)
probably installed the instrument driver one level too deep, Depending on how you unzipped the file.
greetings from the Netherlands
Message 3 of 8
(4,148 Views)
Albert,
I installed the driver using the 'Find Instrument Drivers' option and saw the same thing.
Message 4 of 8
(4,148 Views)
then NI should be informed
I'll report it.
Message 5 of 8
(4,146 Views)
The palettes have been updated to include VIs from the tktdsxxx.llb
Message 6 of 8
(4,119 Views)
Message 7 of 8
(4,114 Views)
Thanks to all.
Message 8 of 8
(4,102 Views)
