paroscientific sending wrong data
So I have a quandry and I don't know if it's me trying to recieve bad data from LabView, but everytime I read the pressure from the paroscientific the pressure comes back +100 psia and then when I go over 100 psia it gives me an error of +1000 psia. I don't know if I am the only one with this problem, but if there is anyone who has tackled this before any help would be appreciated.
(3,269 Views)
Can you provide some additional information about your setup?
What hardware are you using to obtain the signal?
How are you caquiring the data in LabVIEW (DAQ Assistant or DAQmx VIs)?
Have you been able to acquire the proper data in the past or is this new behavior?
Anjelica W.
Product Marketing Manager
FlexLogger and TestStand
(3,253 Views)
