please help me in writing to visa write
       I am communicating with my AVR32 which will give response when it reads(if(uart_char[0]==0x20) and if(uart_char[0]==0x10) lot more like this). I have taken for loop and using the indexed counting for writing the char. As long as i am not getting any reply if do with for loop.
       But i am getting reply if i do with indexed array constant as like below picture. I did not undestand where is the problem. i think probablly, with space infront fo the characyer incase of for loop.
Please some suggest me.
Message 1 of 8
(3,670 Views)
here is the attchment.
Message 2 of 8
(3,669 Views)
What happened to NI forum, is any one angry on me. I am really helpless and cursed by Ni forums. Please some say anything.Smiley Sad
Message 3 of 8
(3,661 Views)
Well, I for one do not understand what your question is or what the images are supposed to show. You are typecasting to 4 bytes. Perhaps that is your misunderstanding?
Message 4 of 8
(3,657 Views)
yes, how can I send with one byte and in the form ascii charcter. How can I convert the decimal loop count(for loop) to one byte ascii character. Yes, the type cast function is giving 4 byte after convertion but i don't know how to change that decimal number count(each iteration count) to one byte ascii. Is there any way for this. can you help me.
Message 5 of 8
(3,648 Views)
Why so difficult, Why not sending characters to visa write, Why hex? Hex is just for humans not machines.
greetings from the Netherlands
Message 6 of 8
(3,642 Views)
      I am sending ascii only to write visa. Problem is before i am sending 4 bytes to write visa instead of one byte ascii character. now it is ok and no more problem with that. I am facing problem with combo box. you can help me here http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/Combo-box-help/m-p/1509960........
             Thank you all and a special thanks to dennis.
Message 7 of 8
(3,641 Views)
To send a single byte, you simply convert the value from the iteration terminal to a U8. Take care on how often the for loop iterates, of course.
Message 8 of 8
(3,638 Views)
