pololu jrk motor control
Hi
I am working on a project where i need to control upto 6 12v brushed DC motors with built-in feedback potentiometers (2amp current draw) and 1 12v dc motor up to 10 amp current draw were i need to regulate the speed.I need to use labview as an interface.
I have been looking at the Pololu Jrk 21v3 usb motor controlers with feedback for this application and was wondering has anyone used these before through serial usb connection with labview.Also if anyone could recomend a suitable motor controler with labview drivers (VIs) for this application it would be much appreciated.
https://www.pololu.com/product/1394
https://www.pololu.com/product/1377
(4,624 Views)
@Lickeen1 wrote:
Hi
Not sure how much software experience you have, but interfacing with the Pololu will require you to know how to translate C# code to LabVIEW.
They have an SDK. https://www.pololu.com/docs/0J41
(4,612 Views)
Hi
Thanks for reply.My coding experience would be basic.Would you know of any other motor controllers that would have
labview drivers (VI's) to make it easier to program?I used an arduino and motorshield programed with labview makerhub VI's which works fine,but would like
to look at other alternatives.
(4,607 Views)
@Lickeen1 wrote:
Hi
Sorry, I don't have any knowledge about LabVIEW compatible motor controllers.
(4,599 Views)
