problem concerning an initialize.vi for an HP54600B oscilloscope
In fact our programm is conceived with an initialize.vi module for an HP54600B and an error message occurs :"Old VISA Open dans HP546XXX Initialize.vi"
In fact we thought that it comes from a VISA called Old visa open and we don't understand why this message occurs
if someone has one idea about this problem of communication with our oscilloscope, he will be welcomed.
(3,147 Views)
Make sure you have a recent copy of VISA first. Next, try running the Getting Started.vi that is included with the instrument driver, because it uses the initialize.vi. If this doesn't work there are a few possibilities. It could be the VISA driver, the VI, or the instrument. Try testing the instrument in MAX to verify that you can communicate with it. You might want to upgrade your VISA version or reinstall the instrument driver.
I hope this helps,
Joshua
(3,147 Views)
