problem in handshaking labview software
I am going to develope labview handshaking software for agilient 4294 impedance measurement instrument , I already installed Ni visa 4,4 version,  Agilent 82357B USB/GPIB converter,Agilent IO Libraries Suite,and labview 8.9 , but failed to acess and hand shaking with agilient 4294 impedance measurement instrument , how can I acess it,in this regard I required some sample programs for this instrument
(3,841 Views)
uninstall all agilent software and download the 4294 instrument driver from the NI instrument driver website.
then it should work.
The agilent IO library and LabVIEW don't worrk nicely together.
An alternative is using VEE instead of LabVIEw but better shoot yourself before that.
greetings from the Netherlands
(3,836 Views)
I uninstall all agilent software  but in NI instrument driver website   threre is no   ni    4294 instrument ( only folder for labview examples)  and Agilient 82357B UsB/GPIB driver is exit
(3,817 Views)
If you have an agilent USB -GPIB cable then read about VISA and VISA passport on the forum. It works but not as easy to setup as normal NI hardware.
The agilent IO-libraries are not needed because they also interfere with LabVIEW as far as I know.
So reinstall only the USB-GPIB saftware from agilent and check how to enable it for VISA and if possible at all for MAX.
(3,815 Views)
