problem with hp 6632b error 1073807343
i have problem with hp 6632B i cant communicate with driver hp66xxbc
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E947E659CE034080020E748...
i use lv 8.5.1 visa 4.6  measurement & automation explorer 4.6
in MAX i can communicate and control the hp6632B even using lv visa or I/o asistant I can communicate butt but also attend to use the driver saw me not detected hp66xxbc gpib address and i see
error 1073807343 Insufficient location information or the device or resource is not present in the system
thank you very much for your attention
(4,126 Views)
Accepted by topic author adrian431
That's an IVI driver and you need to configure it in MAX. Did you do that?
(4,121 Views)
thanks problem solved
(4,110 Views)
Hi guys,
I have same problem here.
In my own case I was able to connect to an agilent N9320B using a usb-to-mini-usb cable from my desktop. However after i have taken readings for say 30 seconds then the error comes up on the Labview.
Pls what can I do. I need urgent assistance as it is strange that after some few readings the error probs up.
I can be reached on +12048073466
Thank you
(3,849 Views)
It is not at all the same problem. You have hijacked a solved thread. You have already posted this exact same question in other hijacked threads. All of this adds up to unacceptable behavior on the forum.
(3,843 Views)
