programming avr fuse bits
PLS PLS HELP
I am using avr (atmega 16) to communicate to labview.
i want to use externall oscillator(16Mhz) .i dont know how to programm the fuse bits.i have read about fuse its all clear.
but using AVR studio how can i programm my fuse bits
for
i have searched a lot .the only thing i understand is that i should have a programmer to which controller should be attached online
or what else i dont know
(3,630 Views)
Hi chota,
I'm a little confused, are you planning on using LabVIEW to program the fuse bits or AVR studio?  I can't say I know much about the Atmega 16 but if you have some specific questions about working with LabVIEW I may be able to help.  Can you clarify what you are trying to do?
Cole R.
Software Engineer
(3,615 Views)
