pxie-4112 dc power disable output
I have a PXIe-4112 DC power supply card. I need to disable the output for each channel.
How can I do this?
(4,835 Views)
Hi wdm2015,
You should be able to programmatically set these outputs to zero -  open an example built using the driver that controls this card and set the voltage to 0V.
Kristen M
Automated Test Product Marketing Engineer
(4,805 Views)
