02-07-2015 07:02 PM
I am attempting to control a DS345 function generator over a RS232 serial connection with PyVISA (version 1.6). I am attempting to make an arbitrary waveform with the function generator. All SCPI commands appear to be working, but when I try to send the raw data for the waveform, the device gives a checksum error.
This is especially odd as it works perfectly when I send the message over GPIB.
I was wondering if anybody had any experience with this sort of issue.
Here my code
import visa
from struct import pack
from struct import unpack
import time
import array
def charge_inject():
ADDRESS = "GPIB0::19::INSTR"
__AMP__ = 0.1
__OFFSET__ = 0.1
__BURST_COUNT__ = 25
__DATA__ = [0, 0, 100, 0, 101, -2047, 2101, 0]
rm = visa.ResourceManager()
ds345 = rm.open_resource('ASRL1::INSTR')
ds345.write("*CLS") # clears registers
ds345.write("*SRE 16") # enables "message available bit"
ds345.write("AMPL " + str(__AMP__) + "VP") # sets amplitude
ds345.write("OFFS %f" % __AMP__) # sets offset
ok = ds345.query("LDWF? 1,%i" % (len(__DATA__) / 2)) # tells machine that 'len(__DATA__) / 2' vector vertices will be sent
if str.rstrip(str(ok)) != "1": # quit if there's an error loading the waveform
print "NOT Ready to send waveform"
quit()
else :
print "Ready to send waveform"
# creates binary data to send to the generator, including the checksum
chksum = 0
input = pack('h', 0)
for i in range (1, len(__DATA__)):
input += pack('h', __DATA__[i])
chksum += __DATA__[i]
print __DATA__[i]
print chksum
input += pack('h', chksum)
print input
#print chr(input)
# write_raw is needed rather than just write, since write will try
# to treat input as python's unicode type, which may only take
# 8 bit values
ds345.write_raw(input)
#ds345.write_binary_values('', __DATA__, datatype='h')
ds345.write("FUNC5\n") # sets to arbitrary waveform to produce output
ds345.write("BCNT %i" % __BURST_COUNT__) # sets burst count
ds345.write("TSRC 0") # sets trigger source to single (triggers as many as burst count)
ds345.write("MTYP 5") # sets the type of modulation to burst modulation
ds345.write("MENA 1") # enables modulation
ds345.write("*TRG") # triggers burst'''
charge_inject()
Thank you
