"CAN bus"
An exernal power supply (+8 to +25Vdc) is connected to CAN 1 port on 9853 module.  What is the current requirement for this power supply?
I couldn't find spec in OPERATING INSTRUCTIONS NI 98532-Port, High-Speed CAN Module .pdf.
Thank you for your time and help.
(3,501 Views)
Hi paulknapp,
The product page says 125 mA.
Jordan
(3,495 Views)
I believve that 125mA is for the 5V draw from the chassis.  I am looking for the current requirement for the 8 to 25 V external power that is connected to the CAN 1 output.
Please confirm amount and thank you for your time and help in advance.
(3,493 Views)
You've made a good point. I'll talk to our R&D team and confirm a current requirement for you.
Jordan
(3,479 Views)
After checking with R&D, I was able to confirm that 125mA spec holds true for the draw from the chassis as well as for the external power supply.
(3,470 Views)
