"share" USB scope
I have a Tektronix scope that is USBTMC.
Sometimes we will run a test program on PC#1 and sometimes on PC#2, but *not* at the same time.
Can I buy a hub and let the scope be "shared" between the two PCs?
(4,400 Views)
I haven't done it with USBTMC devices but in MAX you can use VISA server to share a resource over a network.
(4,391 Views)
Ah. I will give it a try at work tomorrow..
Thank you.
(4,385 Views)
