read data from TDS 1002b using Labview with USB
Here the comms scope settings..
Message 41 of 51
(2,045 Views)
That looks okay. Check the cable connection. I don't know what else to try.
Message 42 of 51
(2,038 Views)
Thanks... tomorrow i will connect the scope with RS232...
Message 43 of 51
(2,032 Views)
I already connected the scope with a RS232 cable, but nothing...
I'm sending a prtscr of the NIMAX with the Serial Ports, should the interface name be "Unknown" or i need to install some scope drivers?
I already changed the options to be the same on labview and scope.
What should i do now?
Message 44 of 51
(2,019 Views)
Here the labview parametres configuration and the error...
Message 45 of 51
(2,017 Views)
I don't believe the unknown name should cause a problem. What version of NI-VISA are you using. Perhaps an update or repair could fix the GPIB and serial issues.
Message 46 of 51
(2,003 Views)
Ok! Tomorrow at the lab i will check the version and post it here. Thanks.
Message 47 of 51
(2,000 Views)
Here the version of NI-VISA
Message 48 of 51
(1,984 Views)
That's very old. The latest is at http://www.ni.com/download/ni-visa-5.4.1/4626/en/.
What is your version of LabVIEW and what OS? You would need to check comparability of both.
Message 49 of 51
(1,980 Views)
I'm using the LabView version 9.0, but tomorrow i will install the LabView 2013 and then i will report here if the scope it's working or not. Thank you very much. 🙂
Message 50 of 51
(1,972 Views)
