read serial port at different cpu
Glad that I could help,...but did you solve your problem ?
Message 11 of 15
(1,552 Views)
Hi KC,
A part of my problem is solved. Right now, I need to connect my program thru intranet so
I could monitor AND control it from other computers just like client and server. so what should I do to make this application? How about vi server and web server? Is it will help me??
Please help me..
Thanks..
Message 12 of 15
(1,526 Views)
There are a lot of examples en application notes about the VI server on the web at ni. Further than that I never used it. So cannot help with that.
Message 13 of 15
(1,511 Views)
Hi KC,
Never mind...It's ok..nway thank a lot..but here I have a question to ask you. Right now I using Labview 8.2 and MAX 4.2..Last a few days you have gave me a link to download NI-VISA, right? So after I download the file, my MAX become 4.4 version. Before I installed the file I can make a html file using web publishing tool but after installed that file, I couldnt make the html file. Is it possible that there are some file have been missing or overwritten while the installation process?How could I do in order to get make my MAX 4.2 version and can I use the NI-VISA in MAX 4.2?
Thanks..
Message 14 of 15
(1,508 Views)
You can try to remove the new MAX version and reinstall the 4.2 version from the CD you have.
Not clear to me what you mean with; "I can make a html file using web publishing tool "
Message 15 of 15
(1,506 Views)
