reading from IR camera
Hey guys,
I just got into working with LabVIEW and I have to read the data from an infrared camera that works with UDP network connection. I want my VI to receive the pixel - intensity data and print it out for further procession.
I am quite the beginner and don't really know what to do next. I am also new to reading data sheets from such devices, so it's hard to figure out how to get what I want.
I attached the VI and the data sheet.
After initialization ("Bind HTPA devices" means that only my computer in the network can command the camera) I am using two parallel while loops, one for reading in the camera data and one from sending commands to the camera. I am using the same port no. for writing and reading (the camera port was given in the sheet). In the reading loop I ask wether the incoming data is larger than 548 bytes. If that is the case, it is probably a stream of binary data (data sheet), so as a test I give out the length of the incoming binary datas.
I found out that using the command "t" yields a stream of binary data, it should be the pixel data I wanted. Due to the while loop, the camera sends again and again. Also, it seems like the camera keeps sending even if I stop the programm, because as soon as I start again I receive the same output even without using "t", but that is probably normal since the camera does not care about wether LabVIEW is active or not.
Now my questions: How can I extract the pixel data I need? Is everything alright with my VI?
I would appreciate the help, maybe someone here is used to working with UDP devices like that.
Oh and please try to answer on a beginner level ^^"
Best wishes
Message 1 of 1
(2,564 Views)
