reading serial port
The byte coming across should be less then 100, but I have byte counts useing probe and the number of bytes keeps increasing up to over 5000 ( i'm probeing right ofter the bytes at port node) I'm also probeing at the string line going into the "scan from string" and the read buffter never changes (except for the counting of the time stamp) and after the first time it runs thought the first loop because it thinks the LF is the end of the string and counts the CR as the first part of the next string.
I think I need to change it back to synchronously I was haveing problems writeing waiting of events and it timeing out.
Message 11 of 11
(834 Views)
