relay recommands
i plan to buy   relay for controlling mit labview   two dc Power  supply output on/off,one DC Power Supply (HP E3631A)enable one chanel output 3.5 V,and relay set output on/off,another DC Power Supply (HP E3631A) enable three chanels 1v,+18V,-18V,relay set them on/off.
 i am  really new to  relay switch, i have writed Email to NI service,und waiting for answer,if anyone recommands relay to complete this Switching function that would be appreciated.
Message 1 of 14
(5,775 Views)
Why do you want to switch a power supply output with a relay ?  You can interface with the power supply (GPIB) and switch the output on and off.
Kees
Message 2 of 14
(5,754 Views)
Kees
because i want to deterministic timing controll for  switching between two power supply output,interface with the power supply (GPIB) have kommucationsoverhead
Message 3 of 14
(5,749 Views)
In that case I would use a solid state relay. No contact bounce and better timing.
I think you are from Germany. Look a 'Schuricht' for 'solid state relay'.
Kees
Message 4 of 14
(5,744 Views)
thanks for your recommands, can this Schuricht  solid state relay kontroll  direct mit labview ? i need to a relay that can talk to labview.
Message 5 of 14
(5,740 Views)
No, you need a (low) voltage source to drive the Solid State relay. Maybe a cheap digital output module can do this depending on the type a soldis state relay you need and choose.
Take a look at the datasheet of a solid state relay.
Kees
Message 6 of 14
(5,735 Views)
Kees
where can i choose cheap digital output module?
Message 7 of 14
(5,731 Views)
At NI or cheaper an Arduino UNO
Message 8 of 14
(5,727 Views)
@jetfire wrote:
Kees
You have overhead with communicating to a relay as well. You didn't even try software triggering both of the supplies at once, did you?
Message 9 of 14
(5,716 Views)
@Dennis_Knutson wrote:
@jetfire wrote:
Kees
Hallo, i have read about im attachment Triggered example,but i do not understand,how to use software triggering  both of the supplies at once,i have little experience about it
Message 10 of 14
(5,713 Views)
