02-24-2022 03:51 AM
I am unable to run this code, the connection is well established and IP is detected of the battery simulator (192.168.1.100) in the NI MAX under the remote monitor system and when I run the code it doesn't show the output while accessing the channels, even it is showing remote activated in the controller itself (battery simulator show symbol "R" when it active for remote control), but unable to take readings.
Note: code doesn't show error without connecting the remote system and error initially generated from reference inside the loop.
02-24-2022 04:17 AM
Hello ,, whats your hardware used ?
02-24-2022 06:29 AM
I am using Chroma battery simulator 69200-1, and incorporated SCPI commands listed in the user manual.
02-28-2022 01:25 PM
Bob Schor
