rigol ds1102e crashes after data read
Hello everyone,
I have a Rigol DS1102e scope 2CH scope. I am able to configure it using labview without any issues. I can even grab the captured data and import it to labview.
The problem is, after I do a capture, if I do anything ELSE that changes the scope configuration (like say update vertical V range), the scope goes crazy and stops working responding (the screen shows just random colors all over it).
The only way to get it back to working condition is to turn the scope off AND exit labview altogether. If I just restart the scope labview will throw a VISA error when attempting to recommunicate.
Here is my current code. Hope anyone has any input.
(4,219 Views)
You are blaming LabVIEW for this?
It is the driver you are most likely using which came from them.
Talk to Rigol.
(4,214 Views)
You are correct it is a Rigol driver, that I got from the NI website. I thought I'd ask here anyways just in case.
(4,208 Views)
It is not a driver that was written by NI.
(4,204 Views)
