rodhe&schwarz digital multimeter drivers
I want progaming a digital multimeter (Rohde & Schwarz) with the Serial comunication RS-232. The problem is that this device is very old and i an not sure if exist the drivers. Thank you
(3,549 Views)
Here are all the Keyword Search "Rohde & Schwarz" in the instrument driver library. There are apparently no dmm drivers. You may want to contact the manufacturer to see if they have a driver for their instrument.
Are you looking for a LabVIEW instrument driver specifically? If you are, you can easily create a low-level driver by configuring an I/O assistant VI for each function in the manual. I/O assistant is one of the many new features of LabVIEW 7 and will parse instrument responses for you, which makes creating an instrument driver much easier. Once you have this low level drive
r you can just combine functions to make higher level VIs. Alternatively, you can hire an Alliance Member to write an driver for you.
Alliance Member Directory
http://www.ni.com/alliance/alliance_member.htm
Message Edited by Molly K on 02-18-2005 11:13 PM
(3,550 Views)
