rt-cRIO9024 nidll_vxworks.tlc issues
When trying to integrate real-time into our vi, nidll_vxworks.tlc does not make a .out file when it is built in Simulink. We get a windows error when trying to build it in Simulink where it says "sh.exe has stiooed working" which gives a model error and the build is aborted.
More background:
We are trying to receive real-time data from two sensors via rs232 serial and the cRIO, which is to be fed into our Simulink model that has been converted into a .dll.
(3,327 Views)
WSUcontrols,
Can you provide a more in-depth explanation of what you are trying to do?  Is this a problem with Simulink or LabVIEW?  Are you using the LabVIEW RT toolkit?
Are you using a serial module on the cRIO9024 or using the onboard serial port?
James K
James K.
(3,305 Views)
