run NIvisaic failed on openSUSE13.1, the error occurs : Can't load library /usr/local/lib/liblvrt.so.14.0
Install information:
  OS vsersion : openSUSE 13.1
  NIVISA : nivisa-15.5.0
  NI4822 : NI4882-15.1.1
When I run the command "NIvisaic",the error occurs as following :
libXinerama.so.1: cannot open shared object file: No such file or directory
To download the LabVIEW Runtime engine, go to
http://www.ni.com/rteFinder?dest=lvrte&version=14.0&platform=Linux&lang=en
(5,627 Views)
That error message is pretty clear isn't it?   Download and install the LabVIEW Runtime engine.
(5,616 Views)
Sorry forgot to tell, No matter I install (rpm -Uvh *.rpm) LabVIEW2014RTE_Linux.tgz from http://www.ni.com/download/labview-run-time-engine-2014/4893/en/ or LabVIEW2014RTE_Linux64.tgz from http://www.ni.com/download/labview-run-time-engine-2014/4895/en/ , it will return the error message below: [ error: Failed dependencies: labview-2014-rte >= 14.0.1 is needed by (installed) ni4882i-15.1.0-f0.x86_64 labview-2014-rte >= 14.0.1 is needed by (installed) ni4882i-32bit-15.1.0-f0.x86_64 ] =============================== Finally I can install LabVIEW2015SP1RTE_Linux64.tgz successfully from http://www.ni.com/download/labview-run-time-engine-2015-sp1/5839/en/, but it also return another error message after I type "NIvisaic" like below: [ Can’t load library /usr/local/lib/liblvrt.so.14.0 libXinerama.so.1: cannot open shared object file: No such file or directory To download the LabView Runtime engine, go to http://www.ni.com/rteFinder?dest=lvrte&version=14.0&platform=Linux〈=en ] I already download the LabView Runtime, why this problem still exist? Please help to investigate, thank you.
(5,606 Views)
The error might be a little misleading. This is actually the dependency you will need to resolve. You should be able to find libXinerama in the OpenSUSE package manager. Be sure to install the 32-bit version.
(5,554 Views)
Version : openSUSE 13.1 64bit NIVISA : nivisa-15.5.0 NI4822 : NI4882-15.1.1 Refer to the method of this link can solve the previous issue, thanks. http://digital.ni.com/public.nsf/allkb/A4FDECBA6BD83E2A86257CE8005A22C3 NIvisaic can work but fail to detect the GPIB when the port is linked. Maybe NI4882-15.1.1 cannot support driver for GPIB-USB-HS hardware, so I changed NI4882-15.1.1 to NI4882-2.9.1. But fail to install and display message like below. [ … Do you accept the license?[yng] y … Error: Installed package ni-palni-pal-32bit provides nipali, but does not mark it as obsolete. Installer is aborted. ] Why it fail? And is any method else can solve the detection problem? Thank you.
(5,532 Views)
