run program automatically
Hi, is labview can start to run automatically while windows start, becasue in my project I can not connect PC monitor all the time,if the program can start without press the run botton, that will be great.
(3,327 Views)
While this question seems it would be better suited in the LabVIEW discussion forum, I will offer a possible solution here. You can build your LabVIEW code into an executable and then include that .exe file in the Startup Folder under Start>>Programs>>Startup (Windows XP) There is also an autorun feature in LabVIEW   It is under File>>VI Properties>>Execution. Also, see this other forum post
Brian B
Account Manager
(3,322 Views)
