sample programmes in C# for setting voltage in a TDK lambda power supply
please provide some guidance for setting the voltage of a TDK lambda power supply through GPIB. Any driver software needto be installed?
(5,599 Views)
If you use an NI GPIB controller, then you will need to install NI-488 and it is recommended to install and use NI-VISA. There will be coding examples installed with the drivers. You don't mention the model number but you might find an existing instrument driver from NI or the vendor.
(5,594 Views)
