sampling rate for signal express
Does anyone know where I find the sampling rate and samples to read for the Signal Express when working with a cDAQ-9172?
Maria
(4,735 Views)
You've posted to the wrong board. Use either the multifunction DAQ or SignalExpess board. You've also posted the wrong question. The 9172 is a chassis and you should look at the specs for the acquisition device itself to see its sample rate.
(4,729 Views)
I see, but I'm using the Signal Express board and I don't know where to find the parameters for it.
It's the cDAQ-9172 with 9134 and 9136 modules.
Maria
(4,693 Views)
You aren't making any sense. The 9134 is a controller and there is no 9136. Post back when you find out what days acquisition device you have and post to the correct place or simply use the search box at the top of the page.
https://www.ni.com/en-us/shop/model/cdaq-9134.html
(4,685 Views)
