saving/appending data to data file
Looking for assistance on the following:
BL: Writing/appending data to a data file.
Background:
1. Intent of VI is battery cycling: Repeated charge, discharge cycles
2. Communicating with a DC power supply and programmable load bank via RS-232
3. Program is designed within a 3 state case structure: Charge, Discharge, Dwell(Rest)
4. Intent is to consolidate/append voltage and/or current reading data into a data file as program alternates between 3 states.
Recommendations would be much appreciated.
Regards
Scott
(3,433 Views)
Hi Scott,
which programming language do you use?
Mike
(3,418 Views)
Hello Mike,
Thanks for your inquiry. I was able to get the Write Measurement File block in LabView 8.5.1 to combine the voltage data from multiple case/event structures into one data file. Looks like I'm good to go for the time being.
Scott
(3,394 Views)
