sbRIO-9642 connect with PC by Ethernet
I am using sbRIO-9642 connecting PC by Ethernet
I can find my device in the MAX as following:
It is always shown as "No configured".
And I used command window to show all the devices connected with my PC as following:
I can't find the device with MAC address: 00:80:2f:13:84:76
How to solve this BIG problem, it's a bit annoying!
Thanks a lot
(4,677 Views)
do you set the ip addresses of your PC and sbrio of same domain for example if PC has 192.168.1.1 then sbrio should also have 192.168.1.0,1,2,3,4...... the starting three ie. 192.168.1 should be same for both of them. you can set the first three same
(4,670 Views)
When I connected with the router, the IP address of PC is set automatically to 192.168.1.6. The problem is that sbRIO device can't be found by the router, if contected with PC directly, it can't be found either.
(4,653 Views)
