sbrio9636 VISA Error -1073807202
Hello
I have a sbRIO9636 and the test instruments. I just want to connect sbRIO and Test instruments(with RS232).
I am trying to connect RS232 (9 pin) via serial ports..I also have Measurement & Automation Explorer (ver 5.1) to monitor and configure Serial/parallel connections.
The problem is that when I query, it looks like my device is not properly recognized. I only get time-out errors.  VISA Error -1073807202. But when I connect the Test instruments directly to PC, NI Max shows COM 1 and can get the data from the test instrumnets. That means, I can get the data from PC , but I can't do the same with sbRIO9636.
How can I ensure that my device is properly recognized? Is my COM1 port activated at all? I can't see COM Port in NI Max for sbRIO9636.
thank you!
(6,218 Views)
Accepted by topic author kellydog
Hey Kellydog
This is a kB what the VISA Error -1073807202 is.
http://digital.ni.com/public.nsf/allkb/10C6C0FBB8E7BD4486257850006CE8FF?OpenDocument
maybe this will fix your problem.
best regards,
(6,196 Views)
Hallo Timo.Schroeder,
Thank you for your help. This is do useful!!!!
kellydog
(6,188 Views)
