se7210tp1-e
Intel Server Board se7210TP1-E and PCI-GPIB IEEE 488.2 standard card combo works unstable.
Os W2K SP4, all new drivers and bios updated. GPIB uses new ni488224.zip drivers. Result is bluescreen after test has started (runs some minutes). Tested with two PCI cards which are known good. When test is running GPIB-USB all goes well.
There seems to be something wrong with the board but when tested it the mainboard seems working nicely too. Any ideas?
(3,539 Views)
Can you reply with the Blue Screen information. That will help narrow down the problems.
(3,536 Views)
It says only...
Call your hardware vendor for support
*** The system has halted ***
Not the common bluescreen what Windows usally offer when things go wrong. No mem info or nothing where you can crab 😞
(3,517 Views)
