serial communication problem - TargetSrv.drv
I have communication to a compumotor stepper motor through RS-232 serial
port, from my labview application.  It was working properly without any problems initially.  But recently motor
doesnt respond.  However i can communicate to the motor controller from hyperterminal.  But cannot communicate from the labview application.
There is an application called TargetSrv.drv running in the background.  I dont know what this is.  It came with the new dell PC.  When i manually stop thisapplication, then i dont have communication problem from my labview application.
I am using  LabVIEW  version 7.1
I have Visa Driver Version 3.1 installed
OS :  Windows XP
ThankYou in advance
JAMES JACOB
(3,128 Views)
Sounds like that service is somehow using the serial port. Windows will only allow one application to use the serial port at a time and if that service is some how using the serial port, Windows will block NI-VISA from using the port. Call Dell and ask them what it is. You can probably disable the service by right-clicking on My Computer and select manage. Find the service under the Services folder and change the service from Start Type automatic to manual.
-Josh
(3,125 Views)
