serial communication visa read
When I read the visa in serial communication, the data comes in and the data is broken in the middle. Is this because of the difference in communication speed?
There was a delay before reading the buffer, and a byte read as a property.
시리얼 통신에서 비자 읽기를 할 때, 데이터가 들어오다가 중간에 데이터가 깨져서 들어오는데 이것이 통신 속도의 차이 때문인가요?
버퍼를 읽기전에 딜레이도 걸었고 프로퍼티로 바이트 읽는 것도 걸었습니다.
(3,117 Views)
DO NOT USE THE BYTES AT PORT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (still not enough emphasis)
The Bytes At Port introduced weird race conditions like what you are seeing.  What instrument are you trying to communicate with?  What is the message protocol?  Please share any code you have.  Then we might be able to help you.
(2,980 Views)
