serial communication
I'm Shrinivas Pathak. I'm new to LabVIEW... I've been given a task to send some commands such as ''start motor'', ''stop motor'' etc... i have to send these set of commands through labview inorder to control the motor... i'm stuck with how to send a command which consist of start bit stop bit, checksum, line feed, carriage return and so on.. we are using dspic33f128mc706A chip..
(4,511 Views)
Look in the LabVIEW Example Finder (Help->Find Example) for the Simple Serial Write Read.  That will get you started with serial communication using VISA.  From there, it is a matter of building up your commands.
(4,506 Views)
