serial communication
Hi All,
I have been trying to communicate serially with a mass flow controller (Alicat MC series). I can successfully do this using a terminal (RealTerm). However when I try to do this on labview I am getting no feedback. What I'm trying to do is set up a loop that writes then reads the changes caused by the command. I have followed the basic serial read and write template with no success, and I have also tried using the NI MAX application for testing, and I have had no luck using that either. It claims to successfully write but then says the device is timed out. I tried increasing the time out number but still no luck. I am thinking this is a software issue because I can successfully communicate using a terminal. I have verified that my connections work and I have all the right settings i.e. baud rate, parity, etc. I have attached my program, if there are any errors that anyone can point out, that would be appreciated.
(5,512 Views)
You need to append the termination character to your write data (should be a Line Feed character).  You can just use a property node to make VISA do it for you.
(5,507 Views)
That doesn't seem to be working for me. My property node also only seems to have the option to output the true command and the term char command.
(5,493 Views)
Right-click, Change All To Write.
(5,490 Views)
Did that and still not working. I have used the highlight execution function in the block diagram and on tracing it, it seems that there is no signal going to the read buffer at all.
(5,486 Views)
I have also tried using the manufacturer's VI's and I get error -1073807339, which is a timeout issue. I have attached the VI here.
(5,482 Views)
