serial communication
I am using 4 COM ports to communicate with different instruments in a single application
COM1,COM2 and two PL2303 USB-Serial Converters COM3,COM4
Sometimes,when launching the application I can't data from few instruments
When I open VISA session of particular port, error "VI_ERROR_RSRC_BUSY -The resource is valid but VISA cannot currently access it" appears.
COM1,2,3 works fine and COM4 shows error or COM1,2,4 works fine and COM3 shows error. I am unable to predict which stops communicating at what time.
Why is it so? How can I access data from all ports? The port properties are set correctly and I gave approriate delays between each poll
Please help me regarding this
Thank you
(3,802 Views)
I have had the same error previously, but I don't know if you are having it for the same reason.
In my case, it has happened when I open a connection with one program, vi, sequence, etc. and then attempt to open another connection using the same port with another subvi/sequence/etc.  This can happen especially in labview because processing runs in parallel.  I would check to see if you are having a race condition occurring where you try to access COM3 or COM4 when it has been opened (but not closed) by another subvi or program.
I hope this was helpful.
(3,781 Views)
Thank you
The problem is due to one instrument connected to COM3.It takes long time to release the port!!!
Any how problem is solved.Thank you
(3,775 Views)
