serial port not found in Measurement and Automation
I working in an app where i read from a usb scanner through a virtual serial port at first works just fine but lately the serial port isn't recognize by labview, I checked the port in the device manager and seems Ok  I also checked MAX and doesn't recognized as well, so I figure is something wrong with NI software, I'm using Labview 8.6 with NI-Visa 5.02 in Windows Vista 32-bit.
Hope you can help me with this issue, also I attach a screenshot of the device manager and MAX. Thanks in Advance.
(3,681 Views)
Have you done anything to try to fix the problem? Steps you could take would be uninstalling/installing VISA, unistalling/installing the USB driver.
The problem is with MAX and VISA, not LabVIEW. LabVIEW can only recognize ports that are listed in MAX.
(3,651 Views)
yeah I reinstall USB serial port driver from the manufacturer site, Also NI-VISA, not only that I updated, having at first  visa 4.6, although I haven't reinstall MAX, but MAX only shows the ports that NI-Visa recognize or I'm wrong?
(3,648 Views)
MAX got updated with the new VISA.
Not sure what else you can try. Perhaps deleting all of the aliases in MAX and doing a refresh will help. I'd also try a different USB port on the pc.
(3,643 Views)
